Chronos that can be stopped and start under water
Hi!
I know about this watch and the battery powered Breitling M1 that are chronos with buttons you can use under water. Is there any more?
This one I use to time my showers with... Conditioner has to be in hair for two minutes
Cheers
/john
Cheers
/john
Re: Chronos that can be stopped and start under water
the Omega Chrono Diver serie (300m full functionnal chrono), the Omega Planet Ocean Chrono (600m full functionnal chrono), there's also the TagHeuer that I can't remember the name and reference... I wonder if the JLC Master Diving Compressor Chrono isn't a full functionnal chrono at max depth?
Fabrice a écrit:the Omega Chrono Diver serie (300m full functionnal chrono), the Omega Planet Ocean Chrono (600m full functionnal chrono), there's also the TagHeuer that I can't remember the name and reference... I wonder if the JLC Master Diving Compressor Chrono isn't a full functionnal chrono at max depth?
I googled up this thread:
http://forums.watchuseek.com/showthread.php?t=215268
And quotation:
All of 11 choices ? That's all ? Any other Chrono operate safely under water ?
1. Sinn U1000
2. Tag heuer Aquagraph
3. Breitling Quartz Chrono Avenger
4. Breitling Avenger Seawolf chrono 1000m
5. Omega Seamaster Pro
6. Omega PO
7. IWC Aquatimer Chronographs
8. Longines Hydroconquest Chronographs
9. Casio G-Shocks
10. JLC, MC Dive Chronograph
11. Ball Engineer Hydrocarbon Trieste-600m
I hadn't realize this is such a rare functionality.....good thing I asked or I would have made some unsafe assumption in thinking most 200M WR rated Chrono can do this?
Cheers
/john
yep I forgot the well known U1000 around here
Hi John,
The first picture is simply wonderful .
I've just wanted to congratulate you.
Cordially, Jean-Jacques.
All Seamaster chronographs (Seamaster Bond Chrono, Seamaster Blakexpedition and Planet Ocean chrono) , but also the Sinn U-1000 chrono pushers can be used under water
Paneristi88 a écrit:Hi John,
Merci merci!
Cheers
/john
» Retour a zéro des chronos
» Des infos sur la validation de l'Open Water
» Le premier Open Water Français
» G Shock Test - Water Pressure Resistance
» Bon anniversaire Chronos !
